Mitsubishi EVO X (10) Concept Uradno
OdgovorNapisal/-a ND4SPD » 28 sep 2005 18:47
Press objava
Predstavljen bo drugi mesec v Tokyo Motor Show
MITSUBISHI Concept-X
With an exterior that carries over the full flavor of Lancer Evolution's spartan road machine image and a high quality interior with a functional layout that encourages the driver to concentrate solely on operating his machine, MITSUBISHI Concept-X points to way a new-age Evolution design that is as handsome and purposeful as it is functional.
In the mechanical components department, MITSUBISHI Concept-X mates a turbocharged aluminum cylinder block MIVEC engine to a high-performance 6-speed auto-manual transmission. Extensive use is made of aluminum in the roof, engine hood and other body panels. Chassis performance has been substantially improved with the introduction of Mitsubishi's latest 4WD-based Super All Wheel Control (S-AWC) vehicle dynamics control system. The incarnation of driving pleasure, this highly advanced technical specification makes MITSUBISHI Concept-X a showcase on wheels for Mitsubishi Motors' quintessential road performance technology.
Design
The team has crafted a form with lines that are purposeful and handsome; a form that symbolizes the New Mitsubishi Motors Design while retaining the spartan performance image that defines the Lancer Evolution series.
Distinguished by its eye-catching oversized grille, the front visage borrows design cues from a jet fighter to hint broadly at the huge quantities of air it draws in and at the car's road-hugging stability. The brand-identifying 3-diamond logo on the leading edge of the engine hood is another distinguishing element of the new-age Evolution design.
The simple and functional layout of the cockpit is put together in a design that encourages the driver to concentrate fully on operating his machine. The design team has spared no effort in developing coloring and lighting that engender a keener competition look to the interior. The black keynote interior color uses silver counterpoints to impart the material look of aluminum and create a more dynamic and athletic looking interior space.
Powertrain
MITSUBISHI Concept-X is powered by a 2.0-liter 4-cylinder DOHC MIVEC intercooler-turbocharged engine that delivers instant response at all engine speeds with flat torque that keeps pulling up to the red line. MITSUBISHI Concept-X uses a clutchless 6-speed auto-manual transmission that realizes slicker shifting and higher transmission efficiency than a regular manual gearbox. Paddle shifters mounted on the steering column allow the driver to concentrate on his steering better and enable drivers of all abilities to experience the satisfying pleasure of sport driving.
Body and chassis
The ring-structure frame design realizes a significant increase in body stiffness, while the use of aluminum in the engine hood, trunk lid, fenders, roof and front and rear door panels reduces weight. Reducing weight in the roof and upper parts of the body lowers the center of gravity, while weight reduction in the doors, engine hood, trunk and other peripheral elements reduces the moment of inertia for better steerability. Weight reduction, lowering the center of gravity and reducing the moment of inertia all contribute to better motive performance and better handling.
The suspension features a MacPherson strut at the front and a multi-link arrangement at the rear. Working in concert with Mitsubishi Motors' "Roll Control Suspension" technology, this design delivers very high levels of ride and road holding.
On-board Multi-Media System
The On-Board Multi-Media System complements the interior design in the way it encourages a dialogue between driver and machine. The high-definition lcd monitor displays at the back of the front seats that allow them to share with the driver driving-related information and to share fun-to-drive experience.
MITSUBISHI Concept-X showcases Super All Wheel Control (S-AWC) vehicle dynamics control technology. A further step up the evolutionary ladder of Mitsubishi Motors four-wheel drive traction and handling technology well proven in the Lancer Evolution and other series, S-AWC realizes cutting-edge levels of vehicle dynamics control. Based on Mitsubishi's full-time 4WD system, as used in Lancer Evolution, that is built around ACD and Super AYC component technologies, S-AWC adds Active Brake Control, Active Steering System and Roll Control Suspension technologies to realize a fully integrated system.
MITSUBISHI Concept-X specifications
Overall length (mm) 4530
Overall width (mm) 1830
Overall height (mm) 1470
Wheelbase (mm) 2650
Track: F/R (mm) 1565 / 1565
Seating capacity 4
Tires 255/35R20
Wheels 20 x 9J
S-AWC (Super All Wheel Control): The ultimate 4WD-based vehicle dynamics control system, providing integrated and unified control of torque, braking, steering and suspension.
ACD (Active Center Differential): The ACD incorporates an electronically controlled hydraulic multi-plate clutch. An ECU optimizes clutch cover clamp load for different driving conditions, regulating the differential limiting action between free and locked states. The result is improved steering response together with better traction. ACD provides three modes — Tarmac / Gravel / Snow — to enable quicker control response for changes in road surface. A single ECU provides integrated management of both ACD and Super AYC components.
Super AYC (Active Yaw Control): Mitsubishi's Active Yaw Control system uses a torque-transfer mechanism in the rear differential. Under ECU control, the system operates to raise cornering performance by transferring torque between the rear wheels as dictated by driving conditions and so control the yaw moment acting on the car body. In an evolutionary step, switching from the use of a bevel to a planetary gear differential gave Super AYC the ability to transfer almost twice the torque between the rear wheels. As well as reducing understeer further, it delivers LSD-level traction. The use of a single ECU to integrally manage Super AYC with the ACD results in a synergism that makes both components operate more effectively than if they were under independent control.
Lent (MB)-Kongresni trg (LJ)-1h (1.6i 16V HB l.91 130PS)
Portorož-Dolsko-140km-1h 15min (1.4HB l.90 90PS)
ND4SPD
Pridružen: 12 maj 2003 13:26
Kraj: Dolsko
OdgovorNapisal/-a D.J. » 28 sep 2005 18:53
Ammmmmm, zanimivo?
Izognite se nerazumnim kaznim za prehitro vožnjo - www.radardetektor.si
D.J.
Pridružen: 05 apr 2003 13:58
OdgovorNapisal/-a ambrozic » 28 sep 2005 18:53
zgleda k modelcek. mi je prevec dobr tko da to nau ugledal cest :)
.i..
ambrozic
I'm a fish!
Pridružen: 30 nov 2004 15:45
Kraj: Recaro
OdgovorNapisal/-a Zivc » 28 sep 2005 18:58
od spredej ubija :twisted:
www.jdm.si
Zivc
Pridružen: 03 apr 2004 12:34
OdgovorNapisal/-a gas_gas » 28 sep 2005 19:05
matr kwa je grd od znotrej... zunej pa kr vsecen ja :wink:
red beast
gas_gas
Pridružen: 25 maj 2004 20:11
Kraj: Begunje
OdgovorNapisal/-a cury » 28 sep 2005 19:07
Od uzadi je tak k ena Alfa... :?
Men ni všeč... :evil:
Big Bodies Are Made....Not Born!!!
cury
Pridružen: 31 maj 2003 23:48
Kraj: GYM
OdgovorNapisal/-a Domen » 28 sep 2005 19:11
To je pa tok lep pa hud avto, da samo :shock:!
Domen
Pridružen: 18 okt 2003 10:26
OdgovorNapisal/-a ambrozic » 28 sep 2005 19:17
Tud not je hud. Bolj ko gledam bolj mi sede. Tko retro-tehnicen. Masiven in preprost. Surov. Hud je!
.i..
ambrozic
I'm a fish!
Kraj: Recaro
OdgovorNapisal/-a Sinkhet » 28 sep 2005 19:31
Kad imam para... imam Evo X :P
[size=142][color=red]Honda - The Power Of Dreams[/size][/color]
Honda Civic 1.5 LSi
Sinkhet
Pridružen: 14 maj 2005 13:28
Kraj: Prekmurje
OdgovorNapisal/-a rossifumi » 28 sep 2005 20:18
Norooo :dribble: od spredaj je tak kot SportBack concept.
Stranska linija je huda...zadaj res malo lici na alfo ampak sede.
Ce pride v taki obliki tudi v redno prodajo... :twisted:
Lp!
R.
rossifumi
Pridružen: 25 okt 2004 10:16
Kraj: Tavullia
OdgovorNapisal/-a G-4S » 28 sep 2005 20:35
Hud 8)
Samo a je to EVO X (iks) al 10? Ker govorijo o konceptu X in ne 10 :?:
OdgovorNapisal/-a Sinkhet » 28 sep 2005 20:45
G-4S je napisal/-a:Hud 8)
X = rimska deset.. vsi evoti so označeni z rimskimi številami 8)
Honda Civic 1.5 LSi
Sinkhet
Kraj: Prekmurje
OdgovorNapisal/-a _SKOT_ » 28 sep 2005 20:54
aaaaaaaaa,ne mi to kazat,jst morem še na mojo hondico nek keša zmetat,ne pa takoj začet šparat za tegale. Joj,enkrat bo moj,garantiram,sam če vn pride!
_SKOT_
Pridružen: 31 dec 2004 18:23
Kraj: SLIVICE
OdgovorNapisal/-a G-4S » 28 sep 2005 21:06
Sinkhet je napisal/-a:X = rimska deset.. vsi evoti so označeni z rimskimi številami 8)
Vem ja, sam tuki me mal bega dejstvo, da govorijo o Concept-X in ne EVO X. Ker avto je res tok futurističen, da oznaka concept-"iks" niti ni tako mimo :D
OdgovorNapisal/-a Nightmare » 28 sep 2005 22:50
ja to pa je res strojčina.....huuuuud
sam jst useen čakam novo imprezo :D
Smile now,cry later
Nightmare
Pridružen: 16 maj 2005 23:55
Kraj: Slovenija
OdgovorNapisal/-a Sinkhet » 29 sep 2005 06:24
aaa.. vem kaj misliš ja :D
Honda Civic 1.5 LSi
Sinkhet
Kraj: Prekmurje
OdgovorNapisal/-a NipponStar » 29 sep 2005 08:14
cury je napisal/-a:Od uzadi je tak k ena Alfa... :?
Tud men sliči na alfo sam mi je za razliko od tebe presneto HUD 8)
evoti so bli zmer lepi 8)
Jeremy Clarkson:''It is HONDA so it will probably last longer then our mothers!''
HONDA - vse ostalo je kompromis!
ek4 - The King of 1.6L!
Project: kuham rižoto...
NipponStar
Pridružen: 16 nov 2004 13:50
Kraj: Kp
OdgovorNapisal/-a NipponStar » 29 sep 2005 08:19
ambrozic je napisal/-a:zgleda k modelcek. mi je prevec dobr tko da to nau ugledal cest :)
Mogoče se bojo pa zgledoval po hondi kjer je bil koncept civica praktično enak končnemu izdelku pa je tud dost futurističn 8)
NipponStar
Kraj: Kp
OdgovorNapisal/-a MdrFkr » 29 sep 2005 09:39
NORO!!!!!!
kak avtek... samo glewdaš kako je dober... :shock: :shock: :shock: :dribble: :dribble: :dribble:
kaj čmo... se staramo.
MdrFkr
Pridružen: 29 jun 2004 19:51
Kraj: Popolandija
OdgovorNapisal/-a ambrozic » 29 sep 2005 09:58
Kr ne neham ga gledat.
.i..
ambrozic
I'm a fish!
Kraj: Recaro
