portos je napisal/-a:Za razliko od Toyote, ki nima sklopke, jo Honda hibrid ima. Lahko povem iz svoje izkusnje z Jazz ehev, da se skopka zelo redko vklopi, ker vecino casa vozi avto ali na elektriko ali pa bencinar, kot generator poganja el. motor. Sklepam, da tudi obraba sklopke ne bo nek problem.
eljuero je napisal/-a:portos je napisal/-a:Za razliko od Toyote, ki nima sklopke, jo Honda hibrid ima. Lahko povem iz svoje izkusnje z Jazz ehev, da se skopka zelo redko vklopi, ker vecino casa vozi avto ali na elektriko ali pa bencinar, kot generator poganja el. motor. Sklepam, da tudi obraba sklopke ne bo nek problem.
kako se kaj obnasa jazz na AC?
sportman333 je napisal/-a:@Akul; je to tvoja?
https://www.avto.net/Ads/details.asp?id ... da%20Civic
∗ 30. March 2024 at 7:16:30 pm
c402077c402077
I would like to thank you very much for the tip, I already have rust-brown discoloration on all four rubber doors. You can see that without pulling anything off, just when you push the rubber a little off the door.
At the driver's door, when pulling off the rubber, I encountered small (2 / 3mm) paint chips. Lacquer on one side and pure rust on the other.
Very disappointed with Honda and the quality.
Because now the door on the left always cracks when the sun is shining on it (even when standing, not only when driving) and the cladding in the area of the panoramic roof control likes to crack / crackle.
As much as I like the Civic and I like to drive it very much, but that's annoying.
